So lets take a look at our carburetors
Nothing really magic here, their design is virtually identical to the carb that you'll find on any fuel powered yard implement or gas powered RC airplane you may have
They serve the same purpose as the carb on a glow powered model, they mix the fuel with air in precise amounts so that it can be fed into the motor for combustion.
They have an internal fuel pump to get fuel to the carburetor, they have a throttle to control the engine speed (by controlling the amount of fuel being mixed) and some versions have a "choke" to make starting the motor easier. One thing that the versions for helicopter use have that the ones on the RC airplanes don't is a primer system to get the fuel into the carburetor faster for startup.
These are vacuum fed carburetors, the fuel is not pumped or forced into the motor as with a fuel injection system, the low pressure that's created in the intake side of the motor literally sucks the fuel out of the carburetor. Technically they are known as "diaphragm carburetors". It will become obvious why a little later.
Here are views of a typical carb, in this case a WT-644 which includes both a primer bulb and a "choke" system:
WT644 Intake Side - Choke Open
WT644 Engine Side - Throttle Closed
WT644 - Fuel Primer
WT644 - Fuel Pump Cover
WT644 - Exploded View
Pump system (fuel inlet)
